주요 콘텐츠로 건너뛰기
Canon PIXMA iP3600 Printhead Replacement
  1. Canon PIXMA iP3600 Printhead Replacement, Ink Cartridges: 1 단계, 이미지 1/1
    • Press the power button to turn on the printer.
  2. Canon PIXMA iP3600 Printhead Replacement: 2 단계, 이미지 1/1
    • Pull down the front output tray cover.
  3. Canon PIXMA iP3600 Printhead Replacement: 3 단계, 이미지 1/1
    • Lift the printer lid.
  4. Canon PIXMA iP3600 Printhead Replacement: 4 단계, 이미지 1/1
    • Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
  5. Canon PIXMA iP3600 Printhead Replacement: 5 단계, 이미지 1/2 Canon PIXMA iP3600 Printhead Replacement: 5 단계, 이미지 2/2
    • Push in the white clip to release the ink cartridge from the printhead.
    • Lift the ink cartridge from the printhead.
    • Repeat this process for the remaining ink cartridges.
    • You have successfully removed all ink cartridges.
  6. Canon PIXMA iP3600 Printhead Replacement, Printhead: 6 단계, 이미지 1/1
    • After removing all ink cartridges, lift the printhead lock lever.
  7. Canon PIXMA iP3600 Printhead Replacement: 7 단계, 이미지 1/1
    • Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
    Comment réparer la tête d'impression
    Mohamed el amine Baali - 답글
  8. Canon PIXMA iP3600 Printhead Replacement: 8 단계, 이미지 1/1
    • You have successfully removed your printhead.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Caitlyn
회원 가입일: 10/07/14
1,184 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-3, Leahy Fall 2014 USF Tampa, Team 1-3, Leahy Fall 2014 회원
USFT-LEAHY-F14S1G3
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
fairly helpful, especially the photo's. but I need advice on how to clean the printhead before trying to replace it,
a1halber - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 53
전체 시간: 7,695
