필요한 것
Canon Pixma MP250
All-in-one: printer, scanner and copy machine
Maximum paper size is A4
Build in WiFi
Weight: 5.8 kg
To get to the inside of the printer, you have to take off the scan plate. It is connected to the body of the printer with hinges and screws.
Open the scan plate and you will find the spot to replace the ink. Here you will see the inside of the printer. In the right front corner you can find the blue stick. Twist it to remove it from its gully.
Now, the scan plate can be opened completely.
Search for screws, one in both corners and unscrew them.
After taking out the screws, the valve can be taken off by sliding the part to the right.
Please I can't found the location of the valve
What valve? How to disconnect the cables?
skip to step 5
How To Disconnect Cable
To remove the last cover on the top that is left, unscrew right bottom corner of the middle cover. Unscrew left top corner of the middle cover and lift bottom corner as shown in the second picture. Also in the inner part are two screws hidden. One is assigned with the circle and can be seen. The other one is hidden.
The body of the motherboard can be removed after the middle top is removed.
The body of the motherboard is connected to the body with 4 screws. One assigned with the circle in the picture. The other three can be found on the right side of the body (assigned with the arrows).
After removing the body you can take the little tape off which serves to keep the threads together.
The print board is connected with 7 screws and 3 wires. These screws are situated on the right side of the gray board in the middle.
The flat gray wire is connected to two small motherboards. One of the motherboards is connected with one screw and the other is clicked in.
Slide the first motherboard out of its case and unscrew the one that is connected to the print board.
The blue and red wires are connected to an electro motor and the backside of the printer. The wires are also wrapped around a cylinder. (Can be seen in pictures 2 and 3.)
Follow the wires along the backside of the printer and loosen them everywhere where they are wrapped around the backside.
The cylinder is connected by snap fit systems. After disconnecting the cylinder, the wires are loose.
Taking out the next gear is roughly the same as in the previous step.
Under the rod is the last loose part of the paper roller system. In this step we describe how to take this one out.
There are two screws (overview in third picture) under the rod of the gear, unscrew these in order to take out the piece under the rod.
Now, we will take out the rod completely.
Unscrew the housing of the rod which is connected with two screws and the gear and take the rod out.
Where does that spring on the bottom left of the second picture closest to the printer go?
다른 9명이 해당 안내서를 완성하였습니다.
댓글 7개
A reasonably competent DIYer can follow this usefully. Many thanks
A very good tutorial ! Thank you. My print heads are completely out of adjustment and I can no longer align them with the procedure in the user manual. Any idea ? I’m about throw it away :(
Is the flat washer on the table on STEP 18 the same as the one on the printer in step 19? (STEP 19). Where does this go please?
Is there ANYWHERE I can find the blueprint schematic for this model and it’s parts? There is spring I can’t locate where it goes.
These instructions are not compete.
Step4: You can’t just remove two screws and “lift off” the scan plate. Where are the instuctions/pics on how to detach the two ribbon cables which connect the scan plate to the main unit? They aren’t even mentioned yet can wreck the scan plate if you don’t know how to safely disconnect them first.
And WHAT VALVE???? There is no valve.
