이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
The case is held together with two types of screws: fine thread screws that attach the case to the metal parts below, and coarse thread screws that attach the case to the plastic battery compartment.
Remove the two coarse thread screws on the side of the device, to the left of the camera lens.
Remove the two fine thread screws on the side of the device, to the right of the camera lens.
Remove the two coarse thread screws and the single fine thread screw from bottom the camera.
Gently pry apart the two covers starting from the bottom. When there is a 1/4" gap, run your finger gently along the the top of the camera, on the back cover, to release the three catches that secure the shell.
다른 2명이 해당 안내서를 완성하였습니다.
