소개
Use this guide to remove and replace a dysfunctional LCD display screen of a Canon PowerShot A1000 IS.
도구
도구는 필요하지 않습니다.
부품
부품은 필요하지 않습니다.
  1. Transfer screws to a safe place upon removal. The case is held together with two types of screws: fine thread screws that attach the case to the metal parts below, and coarse thread screws that attach the case to the plastic battery compartment. The case is held together with two types of screws: fine thread screws that attach the case to the metal parts below, and coarse thread screws that attach the case to the plastic battery compartment.
    • Transfer screws to a safe place upon removal.
    • The case is held together with two types of screws: fine thread screws that attach the case to the metal parts below, and coarse thread screws that attach the case to the plastic battery compartment.
  2. Remove the two coarse thread screws on the side of the device, to the left of the camera lens. Remove the two coarse thread screws on the side of the device, to the left of the camera lens.
    • Remove the two coarse thread screws on the side of the device, to the left of the camera lens.
  3. Remove the two fine thread screws on the side of the device, to the right  of the camera lens. Remove the two fine thread screws on the side of the device, to the right  of the camera lens.
    • Remove the two fine thread screws on the side of the device, to the right of the camera lens.
  4. Remove the two coarse thread screws and the single fine thread screw from bottom the camera. Remove the two coarse thread screws and the single fine thread screw from bottom the camera. Remove the two coarse thread screws and the single fine thread screw from bottom the camera.
    • Remove the two coarse thread screws and the single fine thread screw from bottom the camera.
  5. Remove the one coarse thread screw underneath the battery cover. Remove the one coarse thread screw underneath the battery cover.
    • Remove the one coarse thread screw underneath the battery cover.
  6. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  7. Gently pry apart the two covers starting from the bottom.  When there is a 1/4" gap, run your finger gently along the the top of the camera, on the back cover,  to release the three catches that secure the shell. Gently pry apart the two covers starting from the bottom.  When there is a 1/4" gap, run your finger gently along the the top of the camera, on the back cover,  to release the three catches that secure the shell. Gently pry apart the two covers starting from the bottom.  When there is a 1/4" gap, run your finger gently along the the top of the camera, on the back cover,  to release the three catches that secure the shell.
    • Gently pry apart the two covers starting from the bottom. When there is a 1/4" gap, run your finger gently along the the top of the camera, on the back cover, to release the three catches that secure the shell.
  8. Gently remove both sides of the casing. Gently remove both sides of the casing.
    • Gently remove both sides of the casing.
  9. When replacing the cover, remove the AV/USB rubber cover for easier reconstruction. Replace the front cover first leaving a small gap on the left hand side of the device for easy reattachment of the back cover.
    • When replacing the cover, remove the AV/USB rubber cover for easier reconstruction.
    • Replace the front cover first leaving a small gap on the left hand side of the device for easy reattachment of the back cover.
    • Reattach the back cover by aligning it with the front cover and snapping the latches into place. Secure with screws in any order.
  10. Insert wisdom here. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  11. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  12. Insert wisdom here. Insert wisdom here.
  13. Insert wisdom here. Insert wisdom here.
  14. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  15. Insert wisdom here. Insert wisdom here. Insert wisdom here.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Biff Wheeler
회원 가입일: 2012년 06월 06일
762 평판
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 1,045
