주요 콘텐츠로 건너뛰기
Canon PowerShot A200 Batteries Replacement
  1. Canon PowerShot A200 Batteries Replacement, Outer Battery Cover: 1 단계, 이미지 1/2 Canon PowerShot A200 Batteries Replacement, Outer Battery Cover: 1 단계, 이미지 2/2
    • Place the camera so the battery cover is facing up, as shown in the picture.
    • Gently push on the outer battery cover until you hear a click, and then release.
  2. Canon PowerShot A200 Batteries Replacement, Inner Battery Cover: 2 단계, 이미지 1/2 Canon PowerShot A200 Batteries Replacement, Inner Battery Cover: 2 단계, 이미지 2/2
    • To open the inner battery cover, push down on the grey latch until you hear a click, and then release.
    • Remove the dead batteries from the camera.
  3. Canon PowerShot A200 Batteries Replacement, Replacing the Batteries: 3 단계, 이미지 1/1
    • After removing the batteries, insert the new batteries in the proper direction.
    • Now push the black, inner cover down until you hear a click to secure the batteries in place.
    • Push down and forward on the outer cover to secure the latch. Your camera will now be fully charged.
결론
Congratulations, you're done.
Ellen Chambers
회원 가입일: 01/05/11
231 평판
안내서 2개 작성하였습니다
Cal Poly, Team 7-37, Regan Winter 2011 Cal Poly, Team 7-37, Regan Winter 2011 회원
CPSU-REGAN-W11S7G37
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 2,025
