주요 콘텐츠로 건너뛰기
Canon PowerShot A2200 Back Cover Replacement
필요한 것
  1. Canon PowerShot A2200 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Back Cover Replacement: 2 단계, 이미지 1/1
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Back Cover Replacement: 3 단계, 이미지 1/1
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Back Cover Replacement: 4 단계, 이미지 1/3 Canon PowerShot A2200 Back Cover Replacement: 4 단계, 이미지 2/3 Canon PowerShot A2200 Back Cover Replacement: 4 단계, 이미지 3/3
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Back Cover Replacement: 5 단계, 이미지 1/3 Canon PowerShot A2200 Back Cover Replacement: 5 단계, 이미지 2/3 Canon PowerShot A2200 Back Cover Replacement: 5 단계, 이미지 3/3
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
결론
Jessica Huebschman
회원 가입일: 03/22/15
140 평판
안내서 1개 작성함
Baylor, Team 4-5, Williams Spring 2015 Baylor, Team 4-5, Williams Spring 2015 회원
BU-WILLIAMS-S15S4G5
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 27
전체 시간: 917
