소개
This replacement guide requires you to use a Phillips head screwdriver to remove the front cover of the device.
필요한 것
First, remove the batteries and memory card.
Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
Begin taking off the back cover with a plastic opening tool.
Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
Continue taking off the back cover along the left side of the camera as seen in the third picture.
Lift up the electrical ribbon shown to access the next screw.
Remove the 3.9 mm screw with a Phillips #00 screwdriver.
Locate ribbon flap, enclosed in red. (picture 1)
Using a plastic opening tool, lift up the ribbon flap to allow insertion of the LCD ribbon. (picture 2)
Place the LCD screen on the camera and align the ribbon underneath the open ribbon flap. Close the ribbon flap onto the ribbon. (picture 3)
Remove the two 5.3 mm screws circled in red with a Phillips #00 screwdriver.
Remove the 4.4 mm screw circled in orange with a Phillips #00 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
