주요 콘텐츠로 건너뛰기
Canon PowerShot A2300 Back Cover Replacement
필요한 것
  1. Canon PowerShot A2300 Back Cover Replacement, Front Cover: 1 단계, 이미지 1/1
    • Open the A/V Out Digital port cover on the function button side to reveal a screw.
  2. Canon PowerShot A2300 Back Cover Replacement: 2 단계, 이미지 1/3 Canon PowerShot A2300 Back Cover Replacement: 2 단계, 이미지 2/3 Canon PowerShot A2300 Back Cover Replacement: 2 단계, 이미지 3/3
    • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
    • Screws are small and very easily lost.
  3. Canon PowerShot A2300 Back Cover Replacement: 3 단계, 이미지 1/2 Canon PowerShot A2300 Back Cover Replacement: 3 단계, 이미지 2/2
    • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
    • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
  4. Canon PowerShot A2300 Back Cover Replacement: 4 단계, 이미지 1/1
    • Gently lift the bottom of the front cover to roughly a 30 degree angle.
  5. Canon PowerShot A2300 Back Cover Replacement: 5 단계, 이미지 1/1
    • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
  6. Canon PowerShot A2300 Back Cover Replacement, Back Cover: 6 단계, 이미지 1/1
    • Hold the camera in your hands with both thumbs on the screen with the screen faced up.
    • Keep close to the table top in case the camera falls out of your hands.
  7. Canon PowerShot A2300 Back Cover Replacement: 7 단계, 이미지 1/1
    • Pull the the bottom left corner of the cover up about an inch to the point shown in the picture.
    • Do not completely remove the back cover by pulling on the side as shown. The cover is still attached on the top of the camera.
  8. Canon PowerShot A2300 Back Cover Replacement: 8 단계, 이미지 1/1
    • Pry the top off by sliding the spudger under the On/Off button.
  9. Canon PowerShot A2300 Back Cover Replacement: 9 단계, 이미지 1/1
    • Slide the cover to the right and off the camera.
    • Gently pry using the spudger on the right side if necessary.
    • The A/V OUT DIGITAL cover will sometimes become loose and disconnect from the cover
결론
다른 2명이 해당 안내서를 완성하였습니다.
Nathan McMillan
회원 가입일: 03/23/15
366 평판
안내서 2개 작성하였습니다
Baylor, Team 7-14, Williams Spring 2015 Baylor, Team 7-14, Williams Spring 2015 회원
BU-WILLIAMS-S15S7G14
4 회원들
안내서 10개 작성하였습니다
댓글 2개
How to share in photo camera to mobile
s0o149563 - 답글
How to share photos camera to mobile
s0o149563 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 492
