주요 콘텐츠로 건너뛰기
Canon PowerShot A2300 Front Cover Replacement
필요한 것
  1. Canon PowerShot A2300 Front Cover Replacement, Front Cover: 1 단계, 이미지 1/1
    • Open the A/V Out Digital port cover on the function button side to reveal a screw.
  2. Canon PowerShot A2300 Front Cover Replacement: 2 단계, 이미지 1/3 Canon PowerShot A2300 Front Cover Replacement: 2 단계, 이미지 2/3 Canon PowerShot A2300 Front Cover Replacement: 2 단계, 이미지 3/3
    • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
    • Screws are small and very easily lost.
  3. Canon PowerShot A2300 Front Cover Replacement: 3 단계, 이미지 1/2 Canon PowerShot A2300 Front Cover Replacement: 3 단계, 이미지 2/2
    • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
    • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
  4. Canon PowerShot A2300 Front Cover Replacement: 4 단계, 이미지 1/1
    • Gently lift the bottom of the front cover to roughly a 30 degree angle.
  5. Canon PowerShot A2300 Front Cover Replacement: 5 단계, 이미지 1/1
    • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ashley Fincher
회원 가입일: 03/23/15
477 평판
안내서 3개 작성하였습니다
Baylor, Team 7-14, Williams Spring 2015 Baylor, Team 7-14, Williams Spring 2015 회원
BU-WILLIAMS-S15S7G14
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
Are the screws really hard to remove, or is it just me?
Alex Hulinsky - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 572
