주요 콘텐츠로 건너뛰기
Canon PowerShot A3400 IS Flash Assembly Replacement
필요한 것
  1. Canon PowerShot A3400 IS Flash Assembly Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place thumb on area right next to where it says open and slide to the right to open.
  2. Canon PowerShot A3400 IS Flash Assembly Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
  3. Canon PowerShot A3400 IS Flash Assembly Replacement, Plastic Case: 3 단계, 이미지 2개 중 1개 Canon PowerShot A3400 IS Flash Assembly Replacement, Plastic Case: 3 단계, 이미지 2개 중 2개
    • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
  4. Canon PowerShot A3400 IS Flash Assembly Replacement: 4 단계, 이미지 2개 중 1개 Canon PowerShot A3400 IS Flash Assembly Replacement: 4 단계, 이미지 2개 중 2개
    • Place the camera on to the side that has the image stabilizer label.
    • Remove the 5.00 mm screws that are on this side using the screwdriver.
  5. Canon PowerShot A3400 IS Flash Assembly Replacement: 5 단계, 이미지 1개 중 1개
    • Place camera on to the side with the A/V Out Digital Cover facing up.
    • Remove this visible 5.00 mm screw.
    • Pull the A/V Out Digital cover back to uncover the next step.
  6. Canon PowerShot A3400 IS Flash Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 5.00 mm screw from behind the cover.
  7. Canon PowerShot A3400 IS Flash Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Make sure the battery cover is open.
  8. Canon PowerShot A3400 IS Flash Assembly Replacement: 8 단계, 이미지 2개 중 1개 Canon PowerShot A3400 IS Flash Assembly Replacement: 8 단계, 이미지 2개 중 2개
    • Turn the camera onto the side with the A/V out Digital cover.
    • Use your finger to pull this tab to the right.
  9. Canon PowerShot A3400 IS Flash Assembly Replacement: 9 단계, 이미지 3개 중 1개 Canon PowerShot A3400 IS Flash Assembly Replacement: 9 단계, 이미지 3개 중 2개 Canon PowerShot A3400 IS Flash Assembly Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the lens side by using your fingers or a spudger to pry it gently open.
    • Try to pry it loose all around that side so that it is easier to pull off.
  10. Canon PowerShot A3400 IS Flash Assembly Replacement: 10 단계, 이미지 3개 중 1개 Canon PowerShot A3400 IS Flash Assembly Replacement: 10 단계, 이미지 3개 중 2개 Canon PowerShot A3400 IS Flash Assembly Replacement: 10 단계, 이미지 3개 중 3개
    • Using your fingers, pull the screen side gently off.
    • Try to loosen it all around that side so that it is easier to try and pull it off.
  11. Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: 11 단계, 이미지 3개 중 1개 Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: 11 단계, 이미지 3개 중 2개 Canon PowerShot A3400 IS Flash Assembly Replacement, Flash: 11 단계, 이미지 3개 중 3개
    • Remove the three 5 mm screws
  12. Canon PowerShot A3400 IS Flash Assembly Replacement: 12 단계, 이미지 3개 중 1개 Canon PowerShot A3400 IS Flash Assembly Replacement: 12 단계, 이미지 3개 중 2개 Canon PowerShot A3400 IS Flash Assembly Replacement: 12 단계, 이미지 3개 중 3개
    • Remove the screen by pulling at the two points as shown.
  13. Canon PowerShot A3400 IS Flash Assembly Replacement: 13 단계, 이미지 2개 중 1개 Canon PowerShot A3400 IS Flash Assembly Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the metal plate with the plastic opening tool.
  14. Canon PowerShot A3400 IS Flash Assembly Replacement: 14 단계, 이미지 2개 중 1개 Canon PowerShot A3400 IS Flash Assembly Replacement: 14 단계, 이미지 2개 중 2개
    • Remove the 5 mm screw
  15. Canon PowerShot A3400 IS Flash Assembly Replacement: 15 단계, 이미지 3개 중 1개 Canon PowerShot A3400 IS Flash Assembly Replacement: 15 단계, 이미지 3개 중 2개 Canon PowerShot A3400 IS Flash Assembly Replacement: 15 단계, 이미지 3개 중 3개
    • Gently pull the flash assembly away.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Emily Pretorius
회원 가입일: 01/13/15
349 평판
안내서 3개를 작성함
1가이드 댓글
easy to take off but waste of putting it back together..
The Heat - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 15
전체 시간: 715
