주요 콘텐츠로 건너뛰기
Canon PowerShot A3400 IS Plastic Case Replacement
필요한 것
  1. Canon PowerShot A3400 IS Plastic Case Replacement, Battery: 1 단계, 이미지 1/1
    • Place thumb on area right next to where it says open and slide to the right to open.
  2. Canon PowerShot A3400 IS Plastic Case Replacement: 2 단계, 이미지 1/1
    • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
  3. Canon PowerShot A3400 IS Plastic Case Replacement, Plastic Case: 3 단계, 이미지 1/2 Canon PowerShot A3400 IS Plastic Case Replacement, Plastic Case: 3 단계, 이미지 2/2
    • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
  4. Canon PowerShot A3400 IS Plastic Case Replacement: 4 단계, 이미지 1/2 Canon PowerShot A3400 IS Plastic Case Replacement: 4 단계, 이미지 2/2
    • Place the camera on to the side that has the image stabilizer label.
    • Remove the 5.00 mm screws that are on this side using the screwdriver.
  5. Canon PowerShot A3400 IS Plastic Case Replacement: 5 단계, 이미지 1/1
    • Place camera on to the side with the A/V Out Digital Cover facing up.
    • Remove this visible 5.00 mm screw.
    • Pull the A/V Out Digital cover back to uncover the next step.
  6. Canon PowerShot A3400 IS Plastic Case Replacement: 6 단계, 이미지 1/1
    • Remove the 5.00 mm screw from behind the cover.
  7. Canon PowerShot A3400 IS Plastic Case Replacement: 7 단계, 이미지 1/1
    • Make sure the battery cover is open.
  8. Canon PowerShot A3400 IS Plastic Case Replacement: 8 단계, 이미지 1/2 Canon PowerShot A3400 IS Plastic Case Replacement: 8 단계, 이미지 2/2
    • Turn the camera onto the side with the A/V out Digital cover.
    • Use your finger to pull this tab to the right.
  9. Canon PowerShot A3400 IS Plastic Case Replacement: 9 단계, 이미지 1/3 Canon PowerShot A3400 IS Plastic Case Replacement: 9 단계, 이미지 2/3 Canon PowerShot A3400 IS Plastic Case Replacement: 9 단계, 이미지 3/3
    • Remove the lens side by using your fingers or a spudger to pry it gently open.
    • Try to pry it loose all around that side so that it is easier to pull off.
  10. Canon PowerShot A3400 IS Plastic Case Replacement: 10 단계, 이미지 1/3 Canon PowerShot A3400 IS Plastic Case Replacement: 10 단계, 이미지 2/3 Canon PowerShot A3400 IS Plastic Case Replacement: 10 단계, 이미지 3/3
    • Using your fingers, pull the screen side gently off.
    • Try to loosen it all around that side so that it is easier to try and pull it off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Emily Pretorius
회원 가입일: 01/13/15
325 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-1, Sullivan Winter 2015 USF Tampa, Team 1-1, Sullivan Winter 2015 회원
USFT-SULLIVAN-W15S1G1
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 11
전체 시간: 258
