주요 콘텐츠로 건너뛰기
Canon PowerShot A4000 IS Camera Lens Error Troubleshooting
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, If there is a Visible Gap in the Lens: 1 단계, 이미지 1/1
    • The first step for a lens error is to gently clean the leans with a clean cloth. If this does not work, then you proceed with the following steps.
    • Apply gentle pressure to the lens cover and move lens in a circular motion until you hear a "click".
  2. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, If the Menu is Still Accessible: 2 단계, 이미지 1/1
    • Hold down the menu button for at least 10 seconds and select the "Factory Reset" option to reset your lens.
  3. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, If the Menu is Not Accessible: 3 단계, 이미지 1/1
    • Remove the battery from your camera and replace it once it is fully charged or buy a new battery if your current one is over a year old. See Battery Removal for more details.
    • Once the battery is out, remove the memory card from camera as well. See Memory Card Replacement for more details.
    • Turning the camera on without a memory card will reset the camera. If the camera has been reset and displays a memory card error message, then the memory card can be reinserted and the camera turned on once again.
  4. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, Changing the Battery Does Not Work: 4 단계, 이미지 1/2 Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, Changing the Battery Does Not Work: 4 단계, 이미지 2/2
    • Insert the A/V cable then plug the cable into a power supply or computer. Please see Connecting Camera to Computer for further instructions.
    • Turn the camera on by pushing the ON/OFF button.
  5. Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, New Batteries Do Not Work: 5 단계, 이미지 1/2 Canon PowerShot A4000 IS Camera Lens Error Troubleshooting, New Batteries Do Not Work: 5 단계, 이미지 2/2
    • While turning the camera on by pushing the ON/OFF button, press and hold the MENU or FUNC. SET button.
결승점
Ashley Heslip
회원 가입일: 10/13/14
309 평판
안내서 3개 작성하였습니다
Clemson, Team 1-3, Benson Fall 2014 Clemson, Team 1-3, Benson Fall 2014 회원
CLEM-BENSON-F14S1G3
3 회원들
안내서 17개 작성하였습니다
댓글 2개
My lens is stuck out and won't go back in it says lens error and that it will shut off automatically what do I do?
trudiaguilar - 답글
I have done all of the above recommendations and my camera still has a lens error and lens won’t open… :-(
Rosie Bird - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 3,633
