주요 콘텐츠로 건너뛰기
Canon PowerShot A4000 IS SD Card Replacement
필요한 것
  1. Canon PowerShot A4000 IS SD Card Replacement, Reinserting Memory Card: 1 단계, 이미지 1/1
    • The inside of your Canon PowerShot A4000 camera should have a picture showing how to reinsert your memory card.
    • Line the memory card up like it is shown in the camera and using your thumb, press down on the card until you hear a click. Your memory card is now back in place and ready for use.
  2. Canon PowerShot A4000 IS SD Card Replacement, Memory Card Removal: 2 단계, 이미지 1/2 Canon PowerShot A4000 IS SD Card Replacement, Memory Card Removal: 2 단계, 이미지 2/2
    • To open the battery compartment where the memory card is stored, refer to the Battery Replacement Guide.
    • The memory card is stored behind the battery on the side opposite of the lens as outlined by the red rectangle in the picture.
    • To remove the memory card, use your thumb to press down on the exposed part of the card.
    • The card will dip down further into the compartment and then you will hear a click as the card is released.
결론
Ansley Gardner
회원 가입일: 10/13/14
761 평판
안내서 7개 작성하였습니다
Clemson, Team 1-3, Benson Fall 2014 Clemson, Team 1-3, Benson Fall 2014 회원
CLEM-BENSON-F14S1G3
3 회원들
안내서 17개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 7
전체 시간: 786
