주요 콘텐츠로 건너뛰기
Canon PowerShot A460 Back Casing Replacement
필요한 것
  1. Canon PowerShot A460 Back Casing Replacement, Battery: 1 단계, 이미지 1/1
    • Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
    • While still holding the switch, pull the cover down, allowing it to release and open.
  2. Canon PowerShot A460 Back Casing Replacement: 2 단계, 이미지 1/1
    • Tilt the camera slightly to allow the batteries to fall out.
  3. Canon PowerShot A460 Back Casing Replacement: 3 단계, 이미지 1/1
    • Press on and release the memory card to eject it.
  4. Canon PowerShot A460 Back Casing Replacement, Front Casing: 4 단계, 이미지 1/1
    • Unscrew the 5mm Phillips #00 screw from the bottom of the camera.
    • Make sure to keep the different size screws organized to make reassembling the camera simpler.
  5. Canon PowerShot A460 Back Casing Replacement: 5 단계, 이미지 1/1
    • Unscrew the three 2mm Phillips #00 screws that are located on the bottom of the camera.
  6. Canon PowerShot A460 Back Casing Replacement: 6 단계, 이미지 1/1
    • Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
  7. Canon PowerShot A460 Back Casing Replacement: 7 단계, 이미지 1/1
    • Take out the 4mm Phillips #00 screw under the rubber flap on the right end of the camera.
  8. Canon PowerShot A460 Back Casing Replacement: 8 단계, 이미지 1/2 Canon PowerShot A460 Back Casing Replacement: 8 단계, 이미지 2/2
    • Remove the second battery cover on the bottom of camera.
    • Take the silver battery out of the camera.
  9. Canon PowerShot A460 Back Casing Replacement: 9 단계, 이미지 1/3 Canon PowerShot A460 Back Casing Replacement: 9 단계, 이미지 2/3 Canon PowerShot A460 Back Casing Replacement: 9 단계, 이미지 3/3
    • Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
    • Remove the light grey, plastic piece.
    • Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
  10. Canon PowerShot A460 Back Casing Replacement: 10 단계, 이미지 1/3 Canon PowerShot A460 Back Casing Replacement: 10 단계, 이미지 2/3 Canon PowerShot A460 Back Casing Replacement: 10 단계, 이미지 3/3
    • Slightly pull on each side of the camera. It should loosen up and come apart.
    • If it does not pull apart right away, use a little more force.
    • Do not give up!
  11. Canon PowerShot A460 Back Casing Replacement, Back Casing: 11 단계, 이미지 1/1
    • Remove the back case of the camera by pulling from the top.
    • Be careful when pulling off the case. There is a delicate gold ribbon connecting the bottom of the camera to the back case.
결론
Stephanie Friend
회원 가입일: 01/18/13
99 평판
안내서 2개 작성하였습니다
Cal Poly, Team 19-42, Regan Winter 2013 Cal Poly, Team 19-42, Regan Winter 2013 회원
CPSU-REGAN-W13S19G42
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 53
전체 시간: 2,715
