소개
Involving removal of the camera casing as well, this guide will help the user remove the LCD screen to repair or replace it.
필요한 것
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
While still holding the switch, pull the cover down, allowing it to release and open.
Since the tabs have been lifted, the ribbon should now slide out out easily.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Explained in detail, very clear, easy to understand. I just unpacked it for the first time. Still able to do as told. Thank you.
