이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The internal battery is vital for powering your Canon Powershot A550. This guide will show you how to remove and replace your internal battery so that your camera may function properly with a new power supply.
필요한 것
Open the compartment labeled CARD/BATT. located at the bottom of the camera by moving the dark gray button down and sliding the cover to the right.
The opened compartment should look like this.
다른 5명이 해당 안내서를 완성하였습니다.
