주요 콘텐츠로 건너뛰기
Canon PowerShot A550 LCD Screen Replacement
필요한 것
  1. Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: 1 단계, 이미지 1/3 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: 1 단계, 이미지 2/3 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: 1 단계, 이미지 3/3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Canon PowerShot A550 LCD Screen Replacement: 2 단계, 이미지 1/1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Canon PowerShot A550 LCD Screen Replacement: 3 단계, 이미지 1/1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Canon PowerShot A550 LCD Screen Replacement: 4 단계, 이미지 1/2 Canon PowerShot A550 LCD Screen Replacement: 4 단계, 이미지 2/2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Canon PowerShot A550 LCD Screen Replacement: 5 단계, 이미지 1/1
    • The camera should look like this once the front cover is removed.
  6. Canon PowerShot A550 LCD Screen Replacement: 6 단계, 이미지 1/3 Canon PowerShot A550 LCD Screen Replacement: 6 단계, 이미지 2/3 Canon PowerShot A550 LCD Screen Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Canon PowerShot A550 LCD Screen Replacement: 7 단계, 이미지 1/1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
  8. Canon PowerShot A550 LCD Screen Replacement, LCD Screen: 8 단계, 이미지 1/1
    • Use a #00 phillips head screwdriver to remove 2 3.34mm phillips screws holding the LCD screen in place.
  9. Canon PowerShot A550 LCD Screen Replacement: 9 단계, 이미지 1/2 Canon PowerShot A550 LCD Screen Replacement: 9 단계, 이미지 2/2
    • Use an iPod Opening Tool to lift the brown portion of the connector to unlock it.
    • Slide the data cable out of the connector.
    • Caution: Do not force the data cable out of the connector. It may rip!
  10. Canon PowerShot A550 LCD Screen Replacement: 10 단계, 이미지 1/1
    • The LCD screen can now be be removed to be fixed/replaced.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Precilla Tang
회원 가입일: 04/19/11
162 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-6, Regan Spring 2011 Cal Poly, Team 8-6, Regan Spring 2011 회원
CPSU-REGAN-S11S8G6
4 회원들
안내서 22개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 20
전체 시간: 3,604
