소개
You will remove screws from the bottom and sides of the camera in order to remove the cameras back cover.
필요한 것
Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 한 개
i just wanted to by flap to replace over batteries it slides on and off reedalice270@gm.com
Alice Reed - 답글
