주요 콘텐츠로 건너뛰기
Canon PowerShot A590 IS Batteries Replacement
필요한 것
  1. Canon PowerShot A590 IS Batteries Replacement, Batteries: 1 단계, 이미지 1/2 Canon PowerShot A590 IS Batteries Replacement, Batteries: 1 단계, 이미지 2/2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Canon PowerShot A590 IS Batteries Replacement: 2 단계, 이미지 1/1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS Batteries Replacement: 3 단계, 이미지 1/1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Zach
회원 가입일: 10/11/10
281 평판
안내서 6개 작성하였습니다
Cal Poly, Team 9-19, Regan Fall 2010 Cal Poly, Team 9-19, Regan Fall 2010 회원
CPSU-REGAN-F10S9G19
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 36
전체 시간: 7,554
