이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
While the switch is pushed forward, pull the cover away from the camera.
To remove batteries, simply allow them to fall out of the camera.
Use a fingernail to lift the clock battery out of the camera.
Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
Open the battery cover.
Using the iFixit opening tool, push up gently around all edges of the camera.
Remove the four screws near the corners of the LCD using a Phillips #00 screwdriver.
Gently lift the screen from the motherboard.
Keep the LCD pulled back in one hand.
Use an iFixit opening tool to pull the black retaining clip up and disconnect the ribbon.
Desolder the wires from the back of the LCD located in the bottom left corner.
Remove the solder from the wires.
Separate the LCD from the rest of the camera.
다른 한 분이 해당 안내서를 완성하였습니다.
