주요 콘텐츠로 건너뛰기
Canon PowerShot A620 Shutter Button Replacement
필요한 것
  1. Canon PowerShot A620 Shutter Button Replacement, Side Panel: 1 단계, 이미지 1/3 Canon PowerShot A620 Shutter Button Replacement, Side Panel: 1 단계, 이미지 2/3 Canon PowerShot A620 Shutter Button Replacement, Side Panel: 1 단계, 이미지 3/3
    • Unscrew the three Phillips #00 1.6x3mm screws on the side.
    • Lift loose panel from the case.
    • Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
  2. Canon PowerShot A620 Shutter Button Replacement, Bottom Panel: 2 단계, 이미지 1/1
    • Unscrew the two Phillips #00 1.6x3mm screws on the bottom panel.
  3. Canon PowerShot A620 Shutter Button Replacement, Battery Compartment: 3 단계, 이미지 1/1
    • Open the battery door.
    • Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
  4. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: 4 단계, 이미지 1/2 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: 4 단계, 이미지 2/2
    • Lift the terminal cover on the side of the camera.
    • Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
  5. Canon PowerShot A620 Shutter Button Replacement, Top Panel: 5 단계, 이미지 1/1
    • Gently pull the top panel to separate it from the case.
    • Although the top panel will now be free from the rest of the case, it will still be attached to the camera by a ribbon cable.
  6. Canon PowerShot A620 Shutter Button Replacement, Front Panel: 6 단계, 이미지 1/2 Canon PowerShot A620 Shutter Button Replacement, Front Panel: 6 단계, 이미지 2/2
    • Gently pull the front panel to separate it from the camera.
    • The battery terminals are easy to access from this step.
  7. Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: 7 단계, 이미지 1/2 Canon PowerShot A620 Shutter Button Replacement, Terminal Cover: 7 단계, 이미지 2/2
    • Gently pull the terminal cover to separate it from the camera.
  8. Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: 8 단계, 이미지 1/2 Canon PowerShot A620 Shutter Button Replacement, Memory Card Cover: 8 단계, 이미지 2/2
    • Slide the memory card cover down.
    • Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
  9. Canon PowerShot A620 Shutter Button Replacement, Back Panel: 9 단계, 이미지 1/2 Canon PowerShot A620 Shutter Button Replacement, Back Panel: 9 단계, 이미지 2/2
    • Gently pull the back panel to separate it from the camera.
  10. Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: 10 단계, 이미지 1/2 Canon PowerShot A620 Shutter Button Replacement, Metal Plate Screws: 10 단계, 이미지 2/2
    • Unscrew the Phillips #00 1.6x3mm screw located on the top panel.
  11. Canon PowerShot A620 Shutter Button Replacement, Metal Plate: 11 단계, 이미지 1/1
    • Gently lift the metal plate and move it to the side.
  12. Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: 12 단계, 이미지 1/2 Canon PowerShot A620 Shutter Button Replacement, Trigger Button Screws: 12 단계, 이미지 2/2
    • Unscrew the two Phillips #00 1.6x3mm screws that hold in the trigger button.
  13. Canon PowerShot A620 Shutter Button Replacement, Trigger Button: 13 단계, 이미지 1/1
    • The trigger button will fall off once the screws have been removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jaime Abraham
회원 가입일: 09/08/14
350 평판
안내서 3개 작성하였습니다
CSU Fullerton, Team 1-1, Bruce Fall 2014 CSU Fullerton, Team 1-1, Bruce Fall 2014 회원
CSUF-BRUCE-F14S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 19
전체 시간: 1,288
