주요 콘텐츠로 건너뛰기
Canon PowerShot A630 Back Panel Replacement
필요한 것
  1. Canon PowerShot A630 Back Panel Replacement, Front Panel: 1 단계, 이미지 1/2 Canon PowerShot A630 Back Panel Replacement, Front Panel: 1 단계, 이미지 2/2
    • Open the battery door by sliding the tab on the battery door while pushing the battery door away from the camera.
    • Remove batteries.
  2. Canon PowerShot A630 Back Panel Replacement: 2 단계, 이미지 1/2 Canon PowerShot A630 Back Panel Replacement: 2 단계, 이미지 2/2
    • Remove the three indicated .2mm screws using a Phillips #00 screwdriver.
    • Gently pull off side-panel to remove it.
  3. Canon PowerShot A630 Back Panel Replacement: 3 단계, 이미지 1/1
    • Remove the two indicated .2mm screws using a Phillips #00 screwdriver.
  4. Canon PowerShot A630 Back Panel Replacement: 4 단계, 이미지 1/2 Canon PowerShot A630 Back Panel Replacement: 4 단계, 이미지 2/2
    • Remove the indicated .2mm screw using a Phillips #00 screwdriver.
    • Remove the three .2mm screws located on the internal side of the top panel within the battery chamber using a Phillips #00 screwdriver.
  5. Canon PowerShot A630 Back Panel Replacement: 5 단계, 이미지 1/2 Canon PowerShot A630 Back Panel Replacement: 5 단계, 이미지 2/2
    • Open 'DIGITAL A/V OUT' door on camera.
  6. Canon PowerShot A630 Back Panel Replacement: 6 단계, 이미지 1/1
    • Grip the sides of the top panel and gently pull to separate the top panel from the camera body.
    • The top panel will not completely detach.
  7. Canon PowerShot A630 Back Panel Replacement: 7 단계, 이미지 1/2 Canon PowerShot A630 Back Panel Replacement: 7 단계, 이미지 2/2
    • Gently pull the front and back panels apart, and use a Phillips #00 screwdriver to remove the screw connecting the panels.
    • Gripping the top and bottom, gently pull the front panel away from the camera body to remove it.
  8. Canon PowerShot A630 Back Panel Replacement, Back Panel: 8 단계, 이미지 1/2 Canon PowerShot A630 Back Panel Replacement, Back Panel: 8 단계, 이미지 2/2
    • Use the spudger to gently pull back the retaining clip and pull the ribbon out.
    • The top panel should now be completely detached from the camera.
    • Applying too much force to the spudger may damage the retaining clip.
  9. Canon PowerShot A630 Back Panel Replacement: 9 단계, 이미지 1/2 Canon PowerShot A630 Back Panel Replacement: 9 단계, 이미지 2/2
    • Remove .2 mm screw using a #00 Philips screwdriver.
    • Gently pry off back panel to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Alicia Burns
회원 가입일: 10/13/14
600 평판
안내서 5개 작성하였습니다
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014 회원
CLEM-BENSON-F14S2G5
4 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 16
전체 시간: 1,214
