소개
If your camera will not turn on you may need to replace the batteries. Batteries should also be removed before any dis-assembly is performed. This guide will show you how to replace the batteries in your camera.
Slide the tab on the battery door while pushing the battery door out from the camera.
Remove current batteries.
Replace with 4 new AA batteries.
Shut the battery door and slide back toward the camera to lock into place.
다른 2명이 해당 안내서를 완성하였습니다.
