주요 콘텐츠로 건너뛰기
Canon PowerShot A630 LCD Screen Replacement
필요한 것
  1. Canon PowerShot A630 LCD Screen Replacement, LCD Screen: 1 단계, 이미지 1/1
    • Open the LCD screen of the camera
  2. Canon PowerShot A630 LCD Screen Replacement: 2 단계, 이미지 1/2 Canon PowerShot A630 LCD Screen Replacement: 2 단계, 이미지 2/2
    • Rotate the screen so that it is perpendicular to the body of the camera
    • Remove the .2mm screw using a Phillips #00 screwdriver
    • Rotate screen 180 degrees and remove second .2mm screw
  3. Canon PowerShot A630 LCD Screen Replacement: 3 단계, 이미지 1/2 Canon PowerShot A630 LCD Screen Replacement: 3 단계, 이미지 2/2
    • Gently remove the back panel of the LCD screen
  4. Canon PowerShot A630 LCD Screen Replacement: 4 단계, 이미지 1/1
    • Once the back panel is removed another .2mm screw will be revealed, remove this screw to remove the front panel of the LCD screen
  5. Canon PowerShot A630 LCD Screen Replacement: 5 단계, 이미지 1/1
    • Gently remove front panel of the LCD screen
  6. Canon PowerShot A630 LCD Screen Replacement: 6 단계, 이미지 1/2 Canon PowerShot A630 LCD Screen Replacement: 6 단계, 이미지 2/2
    • Locate the ribbon (orange) and using tweezers gently pull back the retaining clip and pull the ribbon out
  7. Canon PowerShot A630 LCD Screen Replacement: 7 단계, 이미지 1/3 Canon PowerShot A630 LCD Screen Replacement: 7 단계, 이미지 2/3 Canon PowerShot A630 LCD Screen Replacement: 7 단계, 이미지 3/3
    • Use a spudger to gently remove the LCD screen from the metal backing plate
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kady Rose
회원 가입일: 10/13/14
198 평판
안내서 1개 작성함
Clemson, Team 2-5, Benson Fall 2014 Clemson, Team 2-5, Benson Fall 2014 회원
CLEM-BENSON-F14S2G5
4 회원들
안내서 18개 작성하였습니다
댓글 한 개
Where can I purchase a replacement LCD screen?
steigw - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 14
30일 전: 40
전체 시간: 2,083
