주요 콘텐츠로 건너뛰기
Canon PowerShot A75 Batteries Replacement
  1. Canon PowerShot A75 Batteries Replacement, Batteries: 1 단계, 이미지 1/1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Batteries Replacement: 2 단계, 이미지 1/3 Canon PowerShot A75 Batteries Replacement: 2 단계, 이미지 2/3 Canon PowerShot A75 Batteries Replacement: 2 단계, 이미지 3/3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Batteries Replacement: 3 단계, 이미지 1/3 Canon PowerShot A75 Batteries Replacement: 3 단계, 이미지 2/3 Canon PowerShot A75 Batteries Replacement: 3 단계, 이미지 3/3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
결론
Put in fresh batteries. Gently shut the flap and slide it forward until you hear a click.
Henry Braden Fisk
회원 가입일: 04/16/12
63 평판
안내서 1개 작성함
Cal Poly, Team 17-30, Amido Spring 2012 Cal Poly, Team 17-30, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G30
5 회원들
안내서 12개 작성하였습니다
댓글 3개
Hi, there is a problem with my Powershot a75. Whenever I switch it on, it just says change the batteries even though they are either new, or fully charged. Thanks
Harry collier - 답글
had same trouble i fix it buy pressing the print button on back next to the disp button it should work then
hot5 - 답글
Probably you have change backup battery which is rechargeable and not easy to change. It is close to chargeable outlet.
Maganbhai Patel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 46
전체 시간: 1,920
