주요 콘텐츠로 건너뛰기
Canon PowerShot A75 Speaker Replacement
필요한 것
  1. Canon PowerShot A75 Speaker Replacement, Batteries: 1 단계, 이미지 1/1
    • Turn the camera over and locate the "BATT OPEN" sliding switch.
  2. Canon PowerShot A75 Speaker Replacement: 2 단계, 이미지 1/3 Canon PowerShot A75 Speaker Replacement: 2 단계, 이미지 2/3 Canon PowerShot A75 Speaker Replacement: 2 단계, 이미지 3/3
    • Slide the switch to the right.
    • The battery cover should slide down and spring open.
  3. Canon PowerShot A75 Speaker Replacement: 3 단계, 이미지 1/3 Canon PowerShot A75 Speaker Replacement: 3 단계, 이미지 2/3 Canon PowerShot A75 Speaker Replacement: 3 단계, 이미지 3/3
    • Remove the 4 AA batteries.
    • Watch for the orientation of the batteries as they slide out.
    • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
  4. Canon PowerShot A75 Speaker Replacement, Speaker: 4 단계, 이미지 1/2 Canon PowerShot A75 Speaker Replacement, Speaker: 4 단계, 이미지 2/2
    • Open the memory card slot by sliding it laterally until you hear a click
    • Remove the 5.9mm screw in the upper corner of the memory card slot
  5. Canon PowerShot A75 Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the two 4.1mm screws at the bottom of the battery flap.
  6. Canon PowerShot A75 Speaker Replacement: 6 단계, 이미지 1/2 Canon PowerShot A75 Speaker Replacement: 6 단계, 이미지 2/2
    • Lift the shutter button and speaker part from the top of the camera.
    • Do not pull the part too hard because there is a plug connecting the speaker to the camera.
  7. Canon PowerShot A75 Speaker Replacement: 7 단계, 이미지 1/3 Canon PowerShot A75 Speaker Replacement: 7 단계, 이미지 2/3 Canon PowerShot A75 Speaker Replacement: 7 단계, 이미지 3/3
    • Using a pair of tweezers, grab the plug that connects the speaker to the camera and gently pull it out.
  8. Canon PowerShot A75 Speaker Replacement: 8 단계, 이미지 1/1
    • Do not proceed to the next step unless you have previous soldering experience because you can damage the flash unit if you are not careful.
    • Remove the glue and unsolder the speaker from the outer casing. Replace or repair the speaker as necessary.
결론
Austin Fox
회원 가입일: 04/11/12
1 평판
안내서 2개 작성하였습니다
Cal Poly, Team 17-30, Amido Spring 2012 Cal Poly, Team 17-30, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G30
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 383
