주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Canon PowerShot A80 Back Cover Replacement
필요한 것
  1. Canon PowerShot A80 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the three Phillips screws (shown) located at the bottom of the camera.
  2. Canon PowerShot A80 Back Cover Replacement: 2 단계, 이미지 1/2 Canon PowerShot A80 Back Cover Replacement: 2 단계, 이미지 2/2
    • Open the door to the CompactFlash memory card slot by sliding it towards you and swinging it open.
    • Remove the memory card if it is still in the camera.
    • Use the Phillips screwdriver to remove the Phillips screw (shown) underneath the memory card slot door.
  3. Canon PowerShot A80 Back Cover Replacement: 3 단계, 이미지 1/1
    • Remove the Phillips screw (shown) located inside the top of the memory card compartment.
  4. Canon PowerShot A80 Back Cover Replacement: 4 단계, 이미지 1/2 Canon PowerShot A80 Back Cover Replacement: 4 단계, 이미지 2/2
    • Open the battery compartment door at the bottom of the camera by sliding the latch to the right and then sliding the door down.
    • Remove the batteries from the compartment.
    • Unscrew the three Phillips screws (shown) located inside the battery compartment.
    • The screw on the left is longer than the other two.
  5. Canon PowerShot A80 Back Cover Replacement: 5 단계, 이미지 1/1
    • You should now able to remove the top lid of the camera.
    • Be cautious of the fragile mylar cable that connects the lid to the main body of the camera.
    • Removing the lid takes a little force. Do this gently. There may be a snapping sound.
    • The door to the memory card compartment will be freed and should be removable now.
    • In other versions of this camera, there is a tab that secures the top from the wrist strap. If yours has this, you won't be able to completely separate the top until you have removed the top screw in Step 8.
  6. Canon PowerShot A80 Back Cover Replacement: 6 단계, 이미지 1/1
    • Remove the lower Phillips screw (shown) from the side of the camera.
    • Open the small rubber door below this screw that covers the connectors.
  7. Canon PowerShot A80 Back Cover Replacement: 7 단계, 이미지 1/2 Canon PowerShot A80 Back Cover Replacement: 7 단계, 이미지 2/2
    • Open and pivot the LCD screen to its widest open position.
    • Remove the rear cover by pulling it straight away from the body of the camera.
    • When reassembling the camera, remember to replace the screws in the same location from which you removed them. Otherwise, you may damage the camera.
결론
konrad
회원 가입일: 01/11/11
220 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-31, Regan Winter 2011 Cal Poly, Team 7-31, Regan Winter 2011 회원
CPSU-REGAN-W11S7G31
6 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 5,296
