소개
The flash assembly is a retractable light bulb fixture that displays a quick burst of background light emited from a light bulb.
부품
지정된 부품이 없습니다.
Now remove the top screw 3.3 mm long on the side of the camera that hold the side panels and the front cover using the #00 screwdriver.
Gently remove the side panel of the camera by pulling it away form the camera.
To reassemble your device, follow these instructions in reverse order. Remember to re-solder any wires that were unsoldered.
다른 한 분이 해당 안내서를 완성하였습니다.
