이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The flash assembly is a retractable light bulb fixture that displays a quick burst of background light emited from a light bulb.
필요한 것
Using a Phillips #00 screwdriver, remove the 3.3 mm long top screw located on the side of the camera. This screw holds the side panels and the front cover together.
To reassemble your device, follow these instructions in reverse order. Remember to re-solder any wires that were unsoldered.
다른 한 분이 해당 안내서를 완성하였습니다.
