주요 콘텐츠로 건너뛰기
Canon PowerShot ELPH 150 IS Back Plate/Menu Button Replacement
필요한 것
  1. Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement, Back Plate/Menu Buttons: 1 단계, 이미지 1/2 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement, Back Plate/Menu Buttons: 1 단계, 이미지 2/2
    • Locate the ON/Off button on the top of the camera and hold it down until the screen and all lights on the camera go dark.
  2. Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: 2 단계, 이미지 1/1
    • Locate the back plate of the camera (contains the LCD screen and menu buttons).
  3. Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: 3 단계, 이미지 1/2 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: 3 단계, 이미지 2/2
    • To remove the back plate you will need to unscrew the 6 support screws securing it to the camera.
    • Use a Phillips #00 screwdriver to remove the first 2 screws on the bottom of the camera.
  4. Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: 4 단계, 이미지 1/3 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: 4 단계, 이미지 2/3 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: 4 단계, 이미지 3/3
    • Remove the next 2 screws located behind the AV port using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: 5 단계, 이미지 1/2 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: 5 단계, 이미지 2/2
    • Use a Phillips #00 screwdriver to remove the final 2 screws from the blue side panel.
  6. Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: 6 단계, 이미지 1/3 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: 6 단계, 이미지 2/3 Canon PowerShot ELPH 150 IS  Back Plate/Menu Button Replacement: 6 단계, 이미지 3/3
    • Use your hands or a spudger to gently pry the front and back case apart along the seams on the bottom of the camera.
    • Completely remove the back plate.
결론
Alex Larrimore
회원 가입일: 03/05/17
305 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S6-G3, Isaacson Spring 2017 UMass Dartmouth, Team S6-G3, Isaacson Spring 2017 회원
UMASSD-ISAACSON-S17S6G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 5
30일 전: 9
전체 시간: 427
