소개
This guide will assist you in replacing the card/battery door on your camera.
Safety First: Power down your camera by locating the ON/Off button on the top of the camera and holding it down until the screen and all lights on the camera go dark.
In order to replace the door, you must first remove the back plate off the camera. Use this guide to do so.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 한 개
Do you know where I can find the sensor pin for the battery door? My Elph 150 won’t turn on and I was thinking that maybe the culprit. I tried new batteries to no avail, also no power when plugged in via usb. Otherwise any ideas what could have caused it, because the camera is in mint condition.
