주요 콘텐츠로 건너뛰기
Canon PowerShot ELPH 310 HS LCD Screen Replacement
필요한 것
  1. Canon PowerShot ELPH 310 HS LCD Screen Replacement, External Panels: 1 단계, 이미지 1/1
    • Use the Phillips #000 screwdriver from the iFixit tool kit to unscrew the two image stabilizer panel’s 2 mm Phillips head screws.
    • Using your hands, remove the image stabilizer panel.
  2. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 2 단계, 이미지 1/2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: 2 단계, 이미지 2/2
    • Unscrew the two 4 mm Phillips head screws from the bottom side of the camera.
  3. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 3 단계, 이미지 1/2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: 3 단계, 이미지 2/2
    • Using your hand, open the battery portal located on the bottom left of the camera. The screw is in the bottom left of the battery portal.
    • Unscrew the hidden 4mm Phillips head screw inside the battery portal.
  4. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 4 단계, 이미지 1/2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: 4 단계, 이미지 2/2
    • Remove the HDMI side panel with your hands.
    • Unscrew the four 4 mm Phillips head screws from the inside of the camera.
  5. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 5 단계, 이미지 1/1
    • The back side of the camera should pop off or be removed by hand.
  6. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 6 단계, 이미지 1/2 Canon PowerShot ELPH 310 HS LCD Screen Replacement: 6 단계, 이미지 2/2
    • Unscrew the one 3 mm Phillips head screw on the top of the camera.
  7. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 7 단계, 이미지 1/1
    • Manually remove the front panel from the camera.
  8. Canon PowerShot ELPH 310 HS LCD Screen Replacement, LCD Screen: 8 단계, 이미지 1/2 Canon PowerShot ELPH 310 HS LCD Screen Replacement, LCD Screen: 8 단계, 이미지 2/2
    • Using your hands, remove the metal piece (surrounding the right side of the screen) from the right side of the camera.
  9. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 9 단계, 이미지 1/1
    • Using your hands, lift up the screen.
    • The screen is fragile!
  10. Canon PowerShot ELPH 310 HS LCD Screen Replacement: 10 단계, 이미지 1/3 Canon PowerShot ELPH 310 HS LCD Screen Replacement: 10 단계, 이미지 2/3 Canon PowerShot ELPH 310 HS LCD Screen Replacement: 10 단계, 이미지 3/3
    • The strip tears easily!
    • Manually lift the shutter button plate and remove the white ZIF connector, which is the white clasp underneath.
    • On the front of the camera, using your fingers, undo the orange ribbon from the gray clasp and pull the ribbon through the shutter deck.
결론
Kadie Aldridge
회원 가입일: 09/23/15
213 평판
안내서 2개 작성하였습니다
University of Alabama, Team 1-4, Sydow campbell Fall 2015 University of Alabama, Team 1-4, Sydow campbell Fall 2015 회원
UA-SYDOW CAMPBELL-F15S1G4
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 11
전체 시간: 965
