주요 콘텐츠로 건너뛰기
Canon PowerShot ELPH330 HS Camera Repair LCD Screen Replacement
필요한 것
  1. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: 1 단계, 이미지 1/2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement, LCD Screen: 1 단계, 이미지 2/2
    • Turn off your camera.
    • Remove the battery.
    • Slide the battery door open with the rubber pad on the bottom right side of the camera.
    • Remove the battery by pushing down on the release button.
  2. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 2 단계, 이미지 1/1
    • Remove the two screws on the left side with a Phillips #00 screwdriver.
  3. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 3 단계, 이미지 1/1
    • Remove the two screws on the bottom of the camera with a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 4 단계, 이미지 1/1
    • Remove the two screws on the right side with a Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 5 단계, 이미지 1/1
    • Using your fingers, carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 6 단계, 이미지 1/2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 6 단계, 이미지 2/2
    • Flip the camera over so that the lens is facing you.
    • Disconnect the highlighted port from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 7 단계, 이미지 1/2 Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 7 단계, 이미지 2/2
    • Remove the bracket around the LCD screen.
  8. Canon PowerShot ELPH330 HS Camera  Repair LCD Screen  Replacement: 8 단계, 이미지 1/1
    • Using the spudger, carefully pry the top to remove the LCD screen.
결론
Michelle Ngo
회원 가입일: 07/23/19
595 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S1-G3, Liner Summer 2019 UW Tacoma, Team S1-G3, Liner Summer 2019 회원
UWT-LINER-SU19S1G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 14
전체 시간: 467
