주요 콘텐츠로 건너뛰기
Canon PowerShot ELPH330 HS Camera Case Replacement
필요한 것
  1. Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: 1 단계, 이미지 1/2 Canon PowerShot ELPH330 HS Camera Case Replacement, Camera Case: 1 단계, 이미지 2/2
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right which will then open the door.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Case Replacement: 2 단계, 이미지 1/1
    • Use the Phillips #00 screwdriver to remove the two screws.
  3. Canon PowerShot ELPH330 HS Camera Case Replacement: 3 단계, 이미지 1/1
    • Remove two more screws using the Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Case Replacement: 4 단계, 이미지 1/1
    • On the lower right side of the camera case, remove the single screw using Phillips #00 screwdriver.
    • On the upper right side of the camera, remove the HDMI A/V out port.
    • Beneath the port cover, remove the screw using the same Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Case Replacement: 5 단계, 이미지 1/1
    • Using your fingers, carefully pry the case apart at the seam.
결론
Michelle Ngo
회원 가입일: 07/23/19
595 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S1-G3, Liner Summer 2019 UW Tacoma, Team S1-G3, Liner Summer 2019 회원
UWT-LINER-SU19S1G3
4 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 9
전체 시간: 175
