주요 콘텐츠로 건너뛰기
Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement
필요한 것
  1. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: 1 단계, 이미지 2개 중 1개 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement, Power/Shutter Button Panel: 1 단계, 이미지 2개 중 2개
    • On the top-center of your device, turn off the camera by pressing the power button.
    • Put your finger on the battery door and slide the battery door to the right to open it.
    • Push the release button downward and it will release the battery.
  2. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Use the Phillips #00 screwdriver to remove the screws.
  3. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the two 4.0mm screws on the bottom of the camera located near the battery door using a Phillips #00 screwdriver.
  4. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 4 단계, 이미지 1개 중 1개
    • At the bottom of the camera next to the battery door, remove two more screws using the Phillips #00 screwdriver.
  5. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 5 단계, 이미지 1개 중 1개
    • To remove the back portion of the camera case, use your fingers to carefully pry the case apart at the seam.
  6. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 6 단계, 이미지 2개 중 2개
    • On the motherboard there should be a white port. Using the spudger, disconnect it from the motherboard.
  7. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 7 단계, 이미지 1개 중 1개
    • Follow the green and white wire. There is a gray piece of rubber holding the button into place. Remove it with the spudger.
  8. Canon PowerShot ELPH330 HS Camera Power/Shutter Button Panel Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the panel off from the top of the camera with your hands.
결론
작성자
6다른 기여자 명과 함께
Michelle Ngo
회원 가입일: 07/23/19
595 평판
안내서 3개를 작성함
UW Tacoma, Team S1-G3, Liner Summer 2019 UW Tacoma, Team S1-G3, Liner Summer 2019 회원
UWT-LINER-SU19S1G3
4 회원들
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 519
