소개
To reassemble the device follow these steps in reverse order.
필요한 것
Pull the switch on the back of the battery case back towards the open arrow to release a latch.
To begin removing the back camera casing, unscrew the Phillips screw underneath the panel covering the USB connections on the side of the camera. Use a Phillips Head 00 screwdriver for this screw.
Remove the screw located directly beneath the USB cover located in the second photo. Use a Phillips Head 00 screwdriver for this screw.
거의 끝나갑니다!
결론
