주요 콘텐츠로 건너뛰기
Canon PowerShot G1 X Mark II Battery Replacement
필요한 것
  1. Canon PowerShot G1 X Mark II Battery Replacement, Battery: 1 단계, 이미지 1/3 Canon PowerShot G1 X Mark II Battery Replacement, Battery: 1 단계, 이미지 2/3 Canon PowerShot G1 X Mark II Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Locate the battery housing cover on the bottom of your camera.
    • Place a finger on the textured portion of the battery housing cover.
    • Slide the cover in the direction that the arrow is pointing.
  2. Canon PowerShot G1 X Mark II Battery Replacement: 2 단계, 이미지 1/2 Canon PowerShot G1 X Mark II Battery Replacement: 2 단계, 이미지 2/2
    • Use your finger to pivot the orange tab away from the battery.
  3. Canon PowerShot G1 X Mark II Battery Replacement: 3 단계, 이미지 1/1
    • Pull the battery out of the housing with your fingers.
결론
To secure the battery back into its housing, follow these instructions in reverse order.
John Kulick
회원 가입일: 01/11/16
239 평판
안내서 1개 작성함
Cal Poly, Team 70-2, Forte Winter 2016 Cal Poly, Team 70-2, Forte Winter 2016 회원
CPSU-FORTE-W16S70G2
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 6
전체 시간: 592
