주요 콘텐츠로 건너뛰기
Canon PowerShot G1 X Screen Casing Replacement
필요한 것
  1. Canon PowerShot G1 X Screen Casing Replacement, Screen Casing: 1 단계, 이미지 1/1
    • Remove the screws on the outside of the screen case shown in the photo.
  2. Canon PowerShot G1 X Screen Casing Replacement: 2 단계, 이미지 1/2 Canon PowerShot G1 X Screen Casing Replacement: 2 단계, 이미지 2/2
    • Remove the screws on the side of the screen casing next to the hinge on the camera.
  3. Canon PowerShot G1 X Screen Casing Replacement: 3 단계, 이미지 1/1
    • Remove the back side of the screen casing. When removing this back casing there will be a clear plastic piece inside, remove this as well. If this is the piece you are servicing, replace it and skip to the conclusion of this guide.
  4. Canon PowerShot G1 X Screen Casing Replacement: 4 단계, 이미지 1/2 Canon PowerShot G1 X Screen Casing Replacement: 4 단계, 이미지 2/2
    • With the plastic piece removed, locate the screws on the outside and inside of the casing shown in the photos. Remove these screws.
  5. Canon PowerShot G1 X Screen Casing Replacement: 5 단계, 이미지 1/1
    • Locate the four clips on the metal piece covering the back of the screen as seen in the photo. Push each of these clips in towards the center of the piece and pull up on the metal plate.
  6. Canon PowerShot G1 X Screen Casing Replacement: 6 단계, 이미지 1/2 Canon PowerShot G1 X Screen Casing Replacement: 6 단계, 이미지 2/2
    • Completely remove the casing from the screen and replace.
결론
Joseph Cosgrove
회원 가입일: 02/12/17
313 평판
안내서 3개 작성하였습니다
USF Tampa, Team 20-1, Remmell Spring 2017 USF Tampa, Team 20-1, Remmell Spring 2017 회원
USFT-REMMELL-S17S20G1
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 28
전체 시간: 505
