도구
부품
지정된 부품이 없습니다.
To begin removing the back camera casing, unscrew the Phillips screw underneath the panel covering the USB connections on the side of the camera. Use a Phillips Head 00 screwdriver for this screw.
Remove the screw located directly beneath the USB cover located in the second photo. Use a Phillips Head 00 screwdriver for this screw.
Locate the view finder on the back of the camera. There is one screw located to the left of the wheel that must be removed before the wheel can be replaced.
다른 한 분이 해당 안내서를 완성하였습니다.
