주요 콘텐츠로 건너뛰기
Canon PowerShot G11 Rear Cover Replacement
필요한 것
  1. Canon PowerShot G11 Rear Cover Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
  2. Canon PowerShot G11 Rear Cover Replacement: 2 단계, 이미지 1/1
    • Remove the four screws on the left side of the camera.
  3. Canon PowerShot G11 Rear Cover Replacement: 3 단계, 이미지 1/1
    • Remove the screw on the right side of the camera.
  4. Canon PowerShot G11 Rear Cover Replacement: 4 단계, 이미지 1/1
    • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
  5. Canon PowerShot G11 Rear Cover Replacement: 5 단계, 이미지 1/1
    • Remove the screw to the right of the view finder on the rear of the camera.
  6. Canon PowerShot G11 Rear Cover Replacement: 6 단계, 이미지 1/1
    • Use the spudger to crack open the case.
  7. Canon PowerShot G11 Rear Cover Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
  8. Canon PowerShot G11 Rear Cover Replacement: 8 단계, 이미지 1/1
    • The rear cover is now unattached from the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dustin Brinegar
회원 가입일: 01/21/15
688 평판
안내서 4개 작성하였습니다
USF Tampa, Team 5-6, Brown Winter 2015 USF Tampa, Team 5-6, Brown Winter 2015 회원
USFT-BROWN-W15S5G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 1,087
