주요 콘텐츠로 건너뛰기
Canon PowerShot G12 Battery Replacement
  1. Canon PowerShot G12 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the camera over with the bottom facing toward you.
    • Place your thumb on the compartment labeled "card/batt open" and slide it outward and up, exposing the battery.
  2. Canon PowerShot G12 Battery Replacement: 2 단계, 이미지 1/1
    • Push out the red latch to release the lock.
    • Remove the battery.
    • Note the battery's position in the terminal.
  3. Canon PowerShot G12 Battery Replacement: 3 단계, 이미지 1/1
    • To insert a new battery, push the red latch out.
    • Insert the battery into the terminal, ensuring the positive end marked with a red arrow is facing downward.
결론
Nathan Meuwissen
회원 가입일: 02/23/15
550 평판
안내서 3개 작성하였습니다
USF Tampa, Team 1-5, Leahy Winter 2015 USF Tampa, Team 1-5, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 18
전체 시간: 1,342
