이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Start to remove all of the screws around the camera: from the front, back, sides, and bottom.
Once the screws have been removed, Remove the back panel. The panel should be able to be removed by hand.
Next remove the front panel and right side panels (the left side is part of the front).
The front of camera should now resemble the picture shown.
To remove the circuit ribbon (the brown strips) pull them out of the plastic pieces they are connected to.
After that you can lift up the capacitor housing by using your finger nail, or other small object, to lift it up around the edges.
Use a spudger, or other thin object, to remove the capacitor from the housing. (Image 2)
To remove the red and yellow wires connected to the capacitor, use a soldering iron to heat up the solder and a vacuum to suck up the solder. Any other methods you know of will also work.
Take the capacitor to you local electronics store or order another capacitor online by reading the capacity off of the side of the capacitor. It should be in microFarads (µF).
Once you have a new capacitor, solder on the red and yellow wires to the same place as the old capacitor.
