주요 콘텐츠로 건너뛰기
Canon PowerShot G3 Speaker Replacement
필요한 것
  1. Canon PowerShot G3 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Start to remove the screws around the camera: from the front, back, sides, and bottom.
  2. Canon PowerShot G3 Speaker Replacement: 2 단계, 이미지 1/1
    • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
  3. Canon PowerShot G3 Speaker Replacement: 3 단계, 이미지 1/1
    • Next remove the front and right side panels (the left is attached to the front panel).
  4. Canon PowerShot G3 Speaker Replacement: 4 단계, 이미지 1/1
    • Finally, remove the top panel as shown.
  5. Canon PowerShot G3 Speaker Replacement: 5 단계, 이미지 1/2 Canon PowerShot G3 Speaker Replacement: 5 단계, 이미지 2/2
    • The front of the camera should now resemble the picture shown. (Image 1)
    • Remove the capacitor/speaker housing using your finger nail or other thin object to lift it up around the edges. (Image 2)
  6. Canon PowerShot G3 Speaker Replacement: 6 단계, 이미지 1/1
    • To remove the circuit ribbon (brown strip) pull it out of the plastic piece it is connected to.
  7. Canon PowerShot G3 Speaker Replacement: 7 단계, 이미지 1/1
    • You should now be able to see how the capacitor/speaker housing slides out of the frame.
  8. Canon PowerShot G3 Speaker Replacement: 8 단계, 이미지 1/2 Canon PowerShot G3 Speaker Replacement: 8 단계, 이미지 2/2
    • Disconnect the speaker wires from the camera, then use a small flat head screw driver to lift the speaker out of its housing.
    • Order a new speaker from the manufacturer or take it to a local electronics store to see if they have one.
결론
Ryan Riales
회원 가입일: 10/22/15
201 평판
안내서 2개 작성하였습니다
University of Memphis, Team 3-2, Kim Fall 2015 University of Memphis, Team 3-2, Kim Fall 2015 회원
UM-KIM-F15S3G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 246
