주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon PowerShot G3 Zoom Control Spring Replacement
필요한 것
    1. Canon PowerShot G3 Zoom Control Spring Replacement, Zoom Control Spring: 1 단계, 이미지 1개 중 1개
      • Start by removing all of the screws around the camera: from the front, back, sides, and bottom.
      댓글 쓰기
    2. Canon PowerShot G3 Zoom Control Spring Replacement: 2 단계, 이미지 1개 중 1개
      • Once the screws are removed, remove the back panel. The panel should be able to be removed by hand.
      댓글 쓰기
    3. Canon PowerShot G3 Zoom Control Spring Replacement: 3 단계, 이미지 1개 중 1개
      • Next remove the front and right side panels (the left side is attached to the front panel).
      댓글 쓰기
    4. Canon PowerShot G3 Zoom Control Spring Replacement: 4 단계, 이미지 1개 중 1개
      • Finally, remove the top panel as shown.
      댓글 쓰기
    5. Canon PowerShot G3 Zoom Control Spring Replacement: 5 단계, 이미지 3개 중 1개 Canon PowerShot G3 Zoom Control Spring Replacement: 5 단계, 이미지 3개 중 2개 Canon PowerShot G3 Zoom Control Spring Replacement: 5 단계, 이미지 3개 중 3개
      • With the top panel removed, locate the metal plate covering the zoom control on the underside of the panel (located on the forward left side, if the panel is oriented similarly to the first image.) This plate will also be connected to some circuit ribbon. Leave the ribbon attached to the plate.
      • Remove the screws from the plate, and lift and fold the plate along the attached circuit ribbon to the right (as shown in third image.)
      댓글 쓰기
    6. Canon PowerShot G3 Zoom Control Spring Replacement: 6 단계, 이미지 2개 중 1개 Canon PowerShot G3 Zoom Control Spring Replacement: 6 단계, 이미지 2개 중 2개
      • With the top panel and metal plate removed, locate the zoom control on the underside of the panel (located on the forward left side if the panel is oriented similarly to the first image.) It will be located directly under the metal plate and circuit ribbon that was removed in the previous step.
      • Once the zoom control is located, remove the faulty zoom control spring from the metal pegs on the panel and zoom control.
      댓글 쓰기
    7. Canon PowerShot G3 Zoom Control Spring Replacement: 7 단계, 이미지 2개 중 1개 Canon PowerShot G3 Zoom Control Spring Replacement: 7 단계, 이미지 2개 중 2개
      • Replace the zoom control spring with a comparable spring, attaching the loop ends to the same metal pegs to which the previous spring was attached (on the panel and zoom control.)
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Cory Jeanes
회원 가입일: 11/07/15
101 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 30
전체 시간: 1,083
