주요 콘텐츠로 건너뛰기
Canon PowerShot G7X Flash Replacement
필요한 것
  1. Canon PowerShot G7X Flash Replacement, Dial: 1 단계, 이미지 1/1
    • Remove the five 2mm Phillips #000 screws that are under the screen of the camera.
  2. Canon PowerShot G7X Flash Replacement: 2 단계, 이미지 1/1
    • Remove the two 3mm Phillips #000 screws under the AV-out digital flap.
    • Remove the two 3 mm Phillips #000 screws from the side of the camera.
  3. Canon PowerShot G7X Flash Replacement: 3 단계, 이미지 1/1
    • Remove the two 3 mm Phillips #000 screws on the side of camera with the flash toggle.
  4. Canon PowerShot G7X Flash Replacement: 4 단계, 이미지 1/1
    • Remove the four 4 mm Phillips #000 screws from the plate on the bottom of the camera.
  5. Canon PowerShot G7X Flash Replacement: 5 단계, 이미지 1/1
    • Remove the back plate.
  6. Canon PowerShot G7X Flash Replacement: 6 단계, 이미지 1/1
    • Remove the three 3 mm Phillips #000 screws around the dial.
  7. Canon PowerShot G7X Flash Replacement: 7 단계, 이미지 1/2 Canon PowerShot G7X Flash Replacement: 7 단계, 이미지 2/2
    • Using the nylon spudger, gently lift the ZIF tab.
    • Disconnect the ribbon cable that connects the dial to the motherboard.
    • Remove the dial from the device.
  8. Canon PowerShot G7X Flash Replacement, Flash: 8 단계, 이미지 1/2 Canon PowerShot G7X Flash Replacement, Flash: 8 단계, 이미지 2/2
    • Remove the three, blue 5 mm Phillips screws from the back plate.
    • Remove seven 2 mm Phillips #000 screws.
  9. Canon PowerShot G7X Flash Replacement: 9 단계, 이미지 1/2 Canon PowerShot G7X Flash Replacement: 9 단계, 이미지 2/2
    • While using the plastic opening tool, gently pry the top plate off the camera.
  10. Canon PowerShot G7X Flash Replacement: 10 단계, 이미지 1/2 Canon PowerShot G7X Flash Replacement: 10 단계, 이미지 2/2
    • Using the black nylon spudger, gently lift the ribbon cable connected to the LCD screen housing until it comes out then remove the housing.
  11. Canon PowerShot G7X Flash Replacement: 11 단계, 이미지 1/2 Canon PowerShot G7X Flash Replacement: 11 단계, 이미지 2/2
    • Remove the 2 mm Phillips #000 screw underneath the top plate.
    • Remove silver plate.
  12. Canon PowerShot G7X Flash Replacement: 12 단계, 이미지 1/1
    • Take the Phillips #000 and remove the three 5 mm screws from the front plate.
  13. Canon PowerShot G7X Flash Replacement: 13 단계, 이미지 1/2 Canon PowerShot G7X Flash Replacement: 13 단계, 이미지 2/2
    • Using the spudger, gently lift the ribbon cable from underneath the front plate.
    • Remove the front plate.
  14. Canon PowerShot G7X Flash Replacement: 14 단계, 이미지 1/2 Canon PowerShot G7X Flash Replacement: 14 단계, 이미지 2/2
    • Remove flash toggle plate.
    • Remove the 2mm Phillips #000 screws under the flash toggle.
  15. Canon PowerShot G7X Flash Replacement: 15 단계, 이미지 1/2 Canon PowerShot G7X Flash Replacement: 15 단계, 이미지 2/2
    • Flash contains charged capacitor. Shock hazard.
    • Using the black nylon spudger, gently lift the ribbon cable that connects the flash to motherboard and remove the flash from the device.
결론
Kyle Pellham
회원 가입일: 04/09/18
420 평판
안내서 2개 작성하였습니다
댓글 한 개
Hi,
great guide, thanks!. Where can I buy the flash?
Best
david olivelli - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 14
30일 전: 114
전체 시간: 2,187
