소개
The motherboard functions as the central hub for all of the components in your device. If one or more components cease to function, the motherboard may be faulty. Follow the directions in this guide to replace the motherboard in your device.
필요한 것
Remove the three, blue 5 mm Phillips screws from the back plate.
Remove seven 2 mm Phillips #000 screws.
Remove the 5 mm Phillips #000 silver, anchor screws from the corners of the motherboard marked in the picture.
다른 한 분이 해당 안내서를 완성하였습니다.
