주요 콘텐츠로 건너뛰기
Canon PowerShot G9 SD-Card Slot Write Lock.
필요한 것
  1. Canon PowerShot G9 SD-Card Slot Write Lock., Open rear cover of camera.: 1 단계, 이미지 1/2 Canon PowerShot G9 SD-Card Slot Write Lock., Open rear cover of camera.: 1 단계, 이미지 2/2
    • Be very careful not to touch any charged flash capacitor
    • Remove screws as marked. 2 for strap holder, 5 for back cover
    • Remove Back cover and strap holder
  2. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Buttons.: 2 단계, 이미지 1/2 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Buttons.: 2 단계, 이미지 2/2
    • Remove the two screws circled green.
    • Remove the buttons.
  3. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: 3 단계, 이미지 1/3 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: 3 단계, 이미지 2/3 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Jog Dial Unit.: 3 단계, 이미지 3/3
    • Disconnect ribbon cable by lifting up flap.
    • Disconnect other cable (another flap)
    • Remove jog dial unit
  4. Canon PowerShot G9 SD-Card Slot Write Lock., Remove Finder dial.: 4 단계, 이미지 1/2 Canon PowerShot G9 SD-Card Slot Write Lock., Remove Finder dial.: 4 단계, 이미지 2/2
    • Remove the one screw circled green.
    • Remove the finder dial
  5. Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: 5 단계, 이미지 1/3 Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: 5 단계, 이미지 2/3 Canon PowerShot G9 SD-Card Slot Write Lock., Remove LCD.: 5 단계, 이미지 3/3
    • Remove screw and lift LCD upwards very carefully. Do not put any strain on cables.
    • Carefully remove flex cables. The left has a flap that needs to be opened (up), the right just needs to be pulled out. Be careful when re-inserting the right one, you can easily damage the fragile cable.
    • Remove the LCD
  6. Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: 6 단계, 이미지 1/3 Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: 6 단계, 이미지 2/3 Canon PowerShot G9 SD-Card Slot Write Lock., Remove main PCB.: 6 단계, 이미지 3/3
    • Remove screws.
    • Disconnect connectors for Lens assembly
    • Carefully disconnect the tiny cable
    • Next step is removing the PCB. I made the mistake not to take care about the battery compartment switch. If you are not careful, the black lever will break off. Not a problem though, because then the camera will work also with opened battery compartmen
    • Remove main PCB by slightly bending outward the cover for the jack with fingernail. Now lift the PCB slightly upwards.
    • Look under the PCB, there is a connector that needs to be separated by means of a small screwdriver or spudger.
    • Re-attaching the connector is not easy. I used a small screwdriver to carefully press the connector back in place.
    • This is not the official method to do this. Normally the Top cover and several other parts need to be removed too.
  7. Canon PowerShot G9 SD-Card Slot Write Lock., Check SD-Card Slot.: 7 단계, 이미지 1/2 Canon PowerShot G9 SD-Card Slot Write Lock., Check SD-Card Slot.: 7 단계, 이미지 2/2
    • Measure continuity with a multimeter on SD-card slot write protect switch.
    • If it is not working, short the two points with a bodge wire, so write lock is disabled
    • Another possible fault is a broken soldering joint holding the case of the SD-card reader in place.
결론
Repeat the steps in order to reassemble your device.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Thomas Widmaier
회원 가입일: 03/05/13
2,063 평판
안내서 10개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,525개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 22
전체 시간: 1,120
