주요 콘텐츠로 건너뛰기
Canon PowerShot S100 Outer Case Replacement
필요한 것
  1. Canon PowerShot S100 Outer Case Replacement, Outer Case: 1 단계, 이미지 1/3 Canon PowerShot S100 Outer Case Replacement, Outer Case: 1 단계, 이미지 2/3 Canon PowerShot S100 Outer Case Replacement, Outer Case: 1 단계, 이미지 3/3
    • Remove the 2 screws (3.2mm, Phillips #00) found on the bottom side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera.
    • Remove the 2 screws (3.2mm, Phillips #00) found on the side of the camera where the terminals are.
    • Open the flap revealing the cable inputs and remove the final screw (3.8mm, Phillips #00) found inside.
  2. Canon PowerShot S100 Outer Case Replacement: 2 단계, 이미지 1/1
    • Turn the camera so that the LCD screen is facing you.
    • Remove the back panel by pulling it off of the camera.
  3. Canon PowerShot S100 Outer Case Replacement: 3 단계, 이미지 1/3 Canon PowerShot S100 Outer Case Replacement: 3 단계, 이미지 2/3 Canon PowerShot S100 Outer Case Replacement: 3 단계, 이미지 3/3
    • Turn the camera so that the lens is facing you.
    • Do not pull the front panel off without removing the ribbon cable first.
    • Slowly lift the front panel from the camera.
    • The ribbon cable is connecting the front panel to the camera. Using the tweezers, gently pull the ribbon cable out of its socket.
    • A spudger may also be used to remove the ribbon cable.
    • Remove the rubber guard that rests on top of the lens.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ricky
회원 가입일: 02/23/15
958 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-4, Leahy Winter 2015 USF Tampa, Team 1-4, Leahy Winter 2015 회원
USFT-LEAHY-W15S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,125
