소개
This guide will tell you how to remove the battery. It is also the beginning step to most guides.
  1. On the bottom of the camera, use your thumb to press the rubber battery cover towards the side of the camera with the strap base. The cover will shift to extend beyond the rest of the camera.
    • On the bottom of the camera, use your thumb to press the rubber battery cover towards the side of the camera with the strap base. The cover will shift to extend beyond the rest of the camera.
  2. Hold the end of the battery cover that extends beyond the camera and lift it up.
    • Hold the end of the battery cover that extends beyond the camera and lift it up.
  3. 아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
    아이폰 배터리 수리 키트
    Only $29.99
    Buy Now
  4. Pull back on the orange tab to release the battery.
    • Pull back on the orange tab to release the battery.
  5. Pull the battery out.
    • Pull the battery out.
결론
Tanya Malalang
회원 가입일: 2011년 01월 12일
325 평판
안내서 3개 작성하였습니다
Cal Poly, Team 13-1, Forte Winter 2011 Cal Poly, Team 13-1, Forte Winter 2011 회원
CPSU-FORTE-W11S13G1
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 1,384
