주요 콘텐츠로 건너뛰기
Canon PowerShot S230 Display Screen Replacement
필요한 것
  1. Canon PowerShot S230 Display Screen Replacement, Display Screen: 1 단계, 이미지 1/1
    • Unscrewing the small screws to take off the backing, screws are on the side and there are 4
  2. Canon PowerShot S230 Display Screen Replacement: 2 단계, 이미지 1/3 Canon PowerShot S230 Display Screen Replacement: 2 단계, 이미지 2/3 Canon PowerShot S230 Display Screen Replacement: 2 단계, 이미지 3/3
    • Pry open the backing
    • Look for all screws before moving on
  3. Canon PowerShot S230 Display Screen Replacement: 3 단계, 이미지 1/1
    • Remove metal shield from camera
    • It's fine if you just use your hands
  4. Canon PowerShot S230 Display Screen Replacement: 4 단계, 이미지 1/1
    • Pry off the the front casing
    • REMOVE ALL SCREWS BEFORE MOVING ON
  5. Canon PowerShot S230 Display Screen Replacement: 5 단계, 이미지 1/2 Canon PowerShot S230 Display Screen Replacement: 5 단계, 이미지 2/2
    • Remove screws and metal shield at the bottom of the camera
  6. Canon PowerShot S230 Display Screen Replacement: 6 단계, 이미지 1/1
    • Remove the screen, also remove any screws that may get in the way, if the screen pops out it’s okay, it’s suppose to do that. Remove the screw at the bottom
  7. Canon PowerShot S230 Display Screen Replacement: 7 단계, 이미지 1/3 Canon PowerShot S230 Display Screen Replacement: 7 단계, 이미지 2/3 Canon PowerShot S230 Display Screen Replacement: 7 단계, 이미지 3/3
    • Remove the highlighted screws to remove the copper facing
    • Now that the screen is replaced, all you need to do is go through the steps in reverse!
결론
Angie
회원 가입일: 05/31/16
101 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 125
